Dave_H_M
Jul 22, 2014Explorer II
Getting Some Heat Out of the RV Storage Barn?
I have an uninsulated pole barn. I know there is not much hope to keep the heat down in there, but maybe if i could get some relief it would make it easier on the fifth wheel I store in there. I considered the gable type mounted one that mounts on the vertical surface close to the gable. I have a loft in the North end of the barn and it will facilitate work from the inside of either the gable mount or thru the roof mount.
Is it worth it in my application.
On the gable one, I have read a lot of reviews that they will flap in the wind. We have some helatious winds from the north here so I guess I could latch it closed permanently in the winter.
Experience with fine winter snow filtering in would also be appreciated. It seems like at least once in a winter we have a big adz north wind with fine snow that i have went to great lengths with the expanding foam to keep out of the north side of the barn.
What do you think I should do - Roof, Gable, or forget it?
