My previous small compressor fridge( 1.7 cubic foot) had no interior light, no drain. I could not get any wire inside through the factory penetrations. I used very thin wire taped tightly to allow the door seal to go over it, at the top of the fridge. I used some low density closed cell foam to help seal the wires.
That 40mm internal fan made a huge difference in cool down times and evenness of internal temps.
That Fridge failed after about 5 years and my New fridge does have an internal light with the magnetic reed switch for the light, but the 12volt source is always hot.
I found a 40mm fan which draws just 0.03amps and moves ~6cfm for this fridge. This fan has the same benefits as the fan in my previous fridge, but also allows a setting of 2 of 7 to hold the same internal temps as a setting of 4 of 7 without the fan. Without the fan the temps will range from 32 to 44f inside when shot with my IR temp gun at various points. With the fan it ranges from 34 to 36.5 f everywhere. If I turn it up to 4 of 7 a gallon jug of milk gets slushy after 24 hours.
Also external temp swings do not require fine tuning of the thermostat dial. We had temps in the low 3 digits a few weeks ago and I expected to have to turn it up higher to maintain sub 39f but found it was still 36.5f or below at a setting of ~2.2 of 7.
I let mine run 24/7.
I can hear the fan sometimes if it is very quiet and it it touching something on the door shelf. I have it hanging on the bamboo skewer with heat shrink holding it in place, and a slight adjustment allows silence again, with the door closed.
Keep in mind the fan motors will contribute somewhat to the heat load the cooling unit needs to remove. For this reason I went with the lowest amp draw fan I could find, and with such a small fridge(1.8 cubic feet), a ~6 cfm fan is plenty and there is no doubt about the performance increase with it.
I mention this because of the "if a little is good, then heaps and gobs above this level must be heaps and gobs better" mentality which permeates our culture.
I'd aim for a fan that can recycle all the volume of the air within the box no more than 3 or 4 times in one minute.
These fans vary greatly in how much Air they move for current consumed and noise made, so research in this area can also have improved results.
Here is one of the most impressive fans available, though at 120MM it might be impractical for most fridges.
http://www.noctua.at/pdf/infosheets/noctua_nf_f12_focused_flow_web.pdf Without the provided inline speed restrictors(low noise adapters) it moves ~53 CFM for 0.05 amps. Most other fans in this CFM range will consume 2 to 3x the current and make a lot more noise.
Not sure what it draws with the LNAs installed but the fan goes from extremely quiet to inaudible. They provide two LNA's and both can be used inline.
This fan is also good at pushing air through a restriction, and in a straight line, where as most fans send air off at a 60 degree angle with 3 or 4 hotspots of airflow. I have one attached to my condenser, pushing air, and the duty cycle dropped with this lower cfm fan pushing air compared to the provided higher cfm fan pulling it through the condenser.
Much much quieter too.
