time2roll
Dec 21, 2020Nomad
I would unplug the fridge as it might be on that "GEN" branch circuit. Remove the outside cover to access the plug.
I would say check the outside outlet for moisture, blow it out with some air. Although this will usually be on a "GFI" branch circuit.
Anything else plugged in to remove? Is the converter on the circuit? I know you replaced it but for testing I would disconnect. Think divide and conquer as you separate components.
