wa8yxm
Jul 20, 2020Explorer III
Most common cause if "Insta-trip" is the patio outlet
howver unplug everything first (sometimes it's not the patio)
if that does not work then remove the cover from the patio outlet and stand back a bit as you might get wet. If you do. dry it out. you may need to replace the outlet and re-seal the cover.
Another cause can be insects but this is not as common. especially with the inst=box type outlets used in RV.s
Now if there was a power issue. it would not insta-trip it simply would not reset (The sound and feel is a touch different)
