Hi Guys, Sorry to be a pain but, I'm confused. I did the breaker routine and found the circuit that is tripping the GFI. However, the breaker is marked general, Where the heck do I start? I am not an...
Are you using a dedicated rv outlet at the house or just one of the gfci protected 15/20 amp outlets. If a dedicated rv outlet then change the breaker for it to a standard breaker. As far as I know the NEC has no requirement for dedicated 30 amp or 50 amp outlets to be gfci protected. If it is not an rv outlet then have one installed. A worthwhile investment.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
