Hi Guys, Sorry to be a pain but, I'm confused. I did the breaker routine and found the circuit that is tripping the GFI. However, the breaker is marked general, Where the heck do I start? I am not an...
Did you ever disconnect the shore power from the rig? You only need to disconnect the neutral(white) wire from the 120 volt distribution neutral buss. It is possible that your cord body is corroded internally causing the GFCI issue.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
