billkaufmann
Jul 26, 2015Explorer
GFI Again
Hi Guys, Sorry to be a pain but, I'm confused. I did the breaker routine and found the circuit that is tripping the GFI. However, the breaker is marked general, Where the heck do I start? I am not an...
Dusty R wrote:
I would guess that somewhere in your RV the neutral, white wire, and ground, green wire, are touching.
Use a volt/ohm meter. With your rig unplugged check for continuity between the ground and neutral prongs on the plug on the shore power cord. There should NOT be any continuity between them.
