billkaufmann's avatar
billkaufmann
GFI Again
Hi Guys,
Sorry to be a pain but, I'm confused. I did the breaker routine and found the circuit that is tripping the GFI. However, the breaker is marked general, Where the heck do I start? I am not an electrician.
  • pconroy328 wrote:
    I don't recall the context - you've got a GFCI outlet that's tripping with no load (nothing plugged in) or under load (something plugged in)?
    What's tripping - the breaker or the outlet itself?
    There are usually several outlets on any circuit. What's going on with the other outlets?
    The other breakers and outlets are ok. I think this circuit has something to do with the inverter and battery charging.
  • I don't recall the context - you've got a GFCI outlet that's tripping with no load (nothing plugged in) or under load (something plugged in)?
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
