Gdetrailer
Mar 04, 2022Explorer III
groundhogy wrote:
Gdetrailer
That could also be true.
I got back from Az in Jan, it was all 8 degrees at night. My poo hose froze along with the dump exit.
I bought a red heat lamp and have it under the trailer.
Plugged into the side outlet full time.
If you do not have one, they do make "in use" outdoor outlet covers which I would suggest..
HERE
They are designed to allow you to have items plugged in and the wire exits out the bottom to prevent rain from getting to the outlet and plug.
NEC requirement for new construction and retrofits..
Beats the old open clamshell "in use" ones that slammed shut as you pulled the plug out..
