groundhogy's avatar
groundhogy
GFI breaker keeps flipping..
So i have a 1990 Excella 29.
It has the mid bath.
My manual shows schematics as rear bath so maybe they never upgraded the manual.
Anyway, whats on this circuit?
-battery charger
-bath outlet
-exterior outlet
-2 other interior outlets
I unplugged anything on the circuit including the charger.
Breaker still flips off.
Take wire out of breaker?
Breaker happy.
Any ideas?
Thanks for reading!
  • Should I order another (if available) GFI style breaker?
    Should I forget the GFI and install a regular breaker?
    (The manual says they normally install a regular breaker except if RV being shipped to a state that demands GFI)
  • So in my mind, a couple things swimming around.,
    -is there actually a wire problem in the walls? Or in some outlet?
    -Or is it just some moisture causing a stray amount of current to trigger the breaker?
    -or.. breakers do wear out
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
