shug23
Nov 11, 2018Explorer
GFI Breaker switch won't reset
Breaker switch wont reset , and hence one plug in the bathroom, 2 plugs in the kitchen and the water heater (using electricity) don't work (surprisingly the dishwasher does). The outlets say GFI protected but there is no button to 'test' the outlet. The RV was in storage in high humidity and I might guess that this is causing the problem. (Today is Day 1 out of storage). If so, will the plugs dry-out ?  Should I replace the outlets with the type of outlet that has the test button right on it to possibly identify the source ?  This is a Mobile Suites 5th wheel.  Thank you
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
- "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread.  Instead, create future threads in the RV FORUM which corresponds to the subject of your topic.  Thank-you!"
