Carolina_Moonsh's avatar
Feb 21, 2015
GFI button
Suddenly this a.m. the GFI red button started popping out after I plugged my curling iron in - in the bathroom. We've been using it for vacuuming, space heater, and curling iron (never at the same time!) for almost a year with no problem and suddenly it started popping out this a.m.
I had vacuumed earlier with no problem. Any idea what might be causing this all of a sudden? We are on 50 amp with a 1995 Newmar Class A gas engine. Thank you!
  • If only the curling iron is popping the GFI it probably is going bad. If the GFI detects a very small stray possible harmful current, it's job is to kick off the circuit.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
