BTPO1
Dec 26, 2013Explorer
As noted above, there is a line side and a load side on a GFCI. If it is hooked up incorrectly it will not work. Another thought is that the problem that caused the trip is still there, try unplugging everything that is on the GFCI circuit and try resetting it then. Maybe the GFCI is doing it's job. JMO
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
