Old-Biscuit
Dec 27, 2013Explorer III
Randyjayco31bhs wrote:
I wired the gfi in correctly I've checked multiple times. I located the live wire with a multimeter so I wired the gfi right as far as live wire and feeder wire. What is the TT?
TT is travel trailer......rv...rig
Bob was asking what is shore power source for your rv?
This post suggests you have shore power ("I located the live wire with a multimeter...")
If you have AC power and GFI is wired correctly and it won't reset then something down stream on that circuit is tripping that GFI
As suggested.....unplug anything plugged into any outlet and then try to reset GFI
If it still trips then recheck how it was wired and then you will need to check each outlet downstream for loose wires/bad contacts/being wet etc.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
