CA_Traveler
Dec 27, 2013Explorer III
Moisture will trip a GFI and it won't reset. The most common moisture areas are outside plugs, refer, kitchen/bath plugs and sometimes even hot water. Unplug everything on the circuit to isolate. Next remove wires from downstream plugs to isolate. I'd start with any outside plugs.
TT = Travel Trailer
Have to ask - did you unplug the vacuum? Don't want to assume anything.
TT = Travel Trailer
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
