westend
Dec 27, 2013Explorer
Randyjayco31bhs wrote:Hopefully, the wire nut exists outside the load center but in a box of some sort. If that isn't the case, you may want to either add a box to enclose that wire nut splice (good time to add a receptacle) or to pull new wire from the outside GFCI to it's own breaker.
The wire nut was there because the outlet outside of the trailer was tied into it so all the GFCI were on the same breaker. Okie way of doing it I guess but ill figure out a more bullet proof way of fixing it.
From what I've seen, AC distribution in most TT's is woefully inadequate. I'm sure this is at the behest of the bean counters that finalize design.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 02, 2026
