ktmrfs
Jul 28, 2014Explorer III
there is a reason it trips, finding the reason is another story. Reasons could be
a) GFI gone bad, does happen.
b) neutral/ground short downstream of the GFI
c) leakage current - which is what GFI checks for, sometimes motors have enough leakage current to trip a GFI, also moisture in any downstream connection
And NO they do not make a "less sensitive" GFI. the trip current is set to be below what would usually cause a fatal shock to a person. And it is a very low current level.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
