notruffinitExplorerNov 07, 2013GFI ProblemI am trying to figure this problem out and don't quite know where to look next. When I plug in to a campground outlet that is GFCI protected, as soon as my surge guard kicks in the GFI protector on th...Show More
Old-BiscuitExplorer IIINov 07, 2013When you turned all the breakers off did that include the Main Breaker(s) alsoTurn ALL breakers OFF and then see if GFCI still trips. If it does...problem is between pedestal and Main PanelBad adapter, bad cord, bad connections in cord, bad wiring.......IF it doesn't trip then turn Main Breaker(s) ON and repeat.Then one breaker at a time.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
