notruffinitExplorerNov 07, 2013GFI ProblemI am trying to figure this problem out and don't quite know where to look next. When I plug in to a campground outlet that is GFCI protected, as soon as my surge guard kicks in the GFI protector on th...Show More
beemerphile1ExplorerNov 08, 2013You have a neutral to ground short as stated above. You need to disconnect all neutrals and reconnect one at a time to isolate the bad circuit. There is no shortcut to diagnosing the problem.There is nothing normal about this happening, you have a dangerous situation and need to get it fixed.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
