klutchdust
Oct 23, 2017Explorer II
ScottG wrote:
It's still just a common GFCI outlet. Just pick one up from Home Depot and replace it.
Ok, I took the inverter cover off and replaced the GFI. It will not reset, I have a green light on the GFI but no power coming out of the GFI. I measured the voltage coming into the GFI and it fluctuates. I have 12 volts going into the inverter. I have 120 volts going into the inverter.
My guess is the inverter has issues. What's troubling is I plugged the satellite dish box and the TV to ground power and I get nothing. Oh boy.
UPDATE:
Removed TV, I have an entertainment center in the front of my coach VS a overhead bunk. The Tv and satellite dish were plugged into another receptacle which was also powered by the Inverter. I checked everything out and fired up the dish. TV will work off the generator power . Heading off to the race in Vegas so I won't be using the TV much anyhow. Hope all my posts help someone else.
