j-d
Oct 23, 2017Explorer II
I may not be saying this right, but I think you have a Pass Through (or maybe should be called Transfer Switch) Inverter. In other words, one that passes 120 VAC from Shore Tie or Generator to the outlet for the TV. Then if there is not 120 VAC to pass through, it creates it from 12 VDC as an Inverter. This one at Amazon is a PSW Inverter with Transfer Switch:
It is hard wired in and out, does not have its own outlet. I don't know if you can use a GFI outlet with it. GFI poses two questions: 1. Will it work properly in Pass Through? and 2. Will it work properly in Inverter Mode?
It is hard wired in and out, does not have its own outlet. I don't know if you can use a GFI outlet with it. GFI poses two questions: 1. Will it work properly in Pass Through? and 2. Will it work properly in Inverter Mode?About Technical Issues
