klutchdust
Oct 24, 2017Explorer II
j-d wrote:
I may not be saying this right, but I think you have a Pass Through (or maybe should be called Transfer Switch) Inverter. In other words, one that passes 120 VAC from Shore Tie or Generator to the outlet for the TV. Then if there is not 120 VAC to pass through, it creates it from 12 VDC as an Inverter. This one at Amazon is a PSW Inverter with Transfer Switch:It is hard wired in and out, does not have its own outlet. I don't know if you can use a GFI outlet with it. GFI poses two questions: 1. Will it work properly in Pass Through? and 2. Will it work properly in Inverter Mode?
The inverter I have does exactly what you stated. It plugs into a wall socket under the sink, it has battery leads coming in and 120 going out to the plugs in the front of the coach.
Once again you have nailed it, thanks for the information.
