Harvey51
Jun 09, 2013Explorer
I would be checking that cord with an ohmmeter. Disconnect it from power! With the breakers tripped, there should be infinite resistance between the hot conductors and ground. A GFI is supposed to trip at about 2 mA corresponding to a resistance of 60 kOhms on 120 V so you will likely see less than that. Now is it the cord or something in the breaker box? The only way to find out is to disconnect the cord at the breaker box. Is the less than 60 k resistance on the cord or is it on the terminals it was connected to? If in the cord and you can disconnect a wire at the plug end, you can tell which wire it is and whether it is the plug or the cord itself.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
