aruba5er
Jun 10, 2013Explorer
Some GFCI's will trip Neutral to Ground ( know that Square D breakers do for sure) and so if you have one shutting off the breaker would not solve anything. Buy and learn to use a VOM= VOLT_OHM_METER. They sell from $2.98 up and sometime they give them away at Harbor Freight. That way you can check if you have any shorts in the cord, see if you have any shorts to frame or if you do have a good ground to the frame. A meter is a necessity. Looking at things doesn"t always produce results.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
