wgriswold
Jun 10, 2013Explorer
I must have a neutral to ground fault as I have eliminated everything else. I will check for shorts with my volt meter and for tight connections at the trailer end of the cord and at the breakers. If that does not work, it is off to the electrician. Thanks for the help and I will let you know the outcome.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
