23hotrodr's avatar
23hotrodr
glass trim install help needed
I have a 2007 Itasca Suncruiser that has 2 windows on the driver's side that aren't like most RV windows. They are a custom made glass panel set into a metal frame and then edged with a rubber molding that is about 5/8" wide and is slightly convex with a "lock" profile along one edge. The glass is either installed in the frame with RTV silicone or butyl tape. Then the edge lock rubber molding slips into the gap around the window and the frame and lies flat on the surface of the glass.
I need to replace the deteriorated rubber molding with new. I have the new rubber molding from Winnebago, but it will not stay in place when the edge lock is slipped into the gap between the glass and frame. It seems like I should use some sort of adhesive to fill the gap and then install the rubber molding and tape it in place until the sealant cures.
What sealant should I use?
My experience with RTV silicone is that it does not adhere well to rubber/vinyl. Should I use Urethane windshield adhesive? I could put a small bead into the groove, install the molding and tape it in place until the Urethane cures. Or, I could just run a bead of urethane into the groove and onto the glass about 1/4" and smooth it out.
What is the correct way for me to do this project? -- Thanks-- Mick
  • Wrong molding! It should be snug. Spray area with glass cleaner and push into place, that's all it should take.
  • I would pay a visit to a local glass installer ,pick his/her brain a little ,ask what type of sealant that they use and why!
    Then buy a bottle or can of glass cleaner,say thanks and go fix the issue!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
