Gonzo42's avatar
Gonzo42
Glow plug
While on our Utah trip I got an engine service light. Scanner tells me I have an open circuit for the glow plug in cylinder 6.
This might be related to what I think was bad diesel but can't be sure.
Has anyone had this problem? What would it take to fix?
2007 MB 6-cyl turbo diesel in a sprinter chassis.
  • I used to test my 6.2 glow plugs by spitting on a finger then RAPIDLY tap the glow plug right after the glow plugs cycled. Be quick or suffer a burned finger.
    Smart folks, use an inductive ammeter and test amperage BEFORE there's a problem. Any and or all problems will instantly show up if you suspect somethings wrong.
  • You can test the GP by putting control light between + what you can find in fuse box and GP cable.
    MB sedans do have plugs on the relay where after pulling it out you will find # of the plug for testing. I assume Sprinter has the same system.
    Getting can of MAF or electronic cleaner and clean the plugs would be in order regardless.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
