mena661
Dec 30, 2013Explorer
Standalone inverters all seem to suck wrt after warranty repair. It seems all the good stuff goes to the inverter/chargers. Mastervolt makes some standalone PSW inverters. Biggest 12V is 1800VA (2000VA for 30 sec) with a 4000VA surge. In order to get a larger capacity unit, you have to get the 24V version (2000VA, 5000VA surge). Might be worth looking into.
EDIT: Why won't you consider an inverter/charger and just simply not use the transfer switch? You could even disable the charger and use it as a backup when you need it. If I were going that route I wouldn't use the built in TS anyways because none of them can pass 50A shore power (except the Victron 5kVA unit I think) and I would want it hooked up whole house anyways.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
