NinerBikes
Feb 27, 2016Explorer
OK folks... title says "Going with Lithium batteries Charging profile revealed".
Revert to the charging graph, and make of it what you will, as a FYI. If you want 90% charged, plan on timing it. I usually try to stop charging on that traction battery with 20 minutes left. 6 minutes for 1 kwh short of full charge at 30 amp charge rate, and 15 minutes for the final 1 kwh short of 21 kwh usable as the current rate decays from 30 amps down to 0, about 10% short.
So I am about 3.5 kwh short of a 100% SOC on a 24.2 kwh capacity battery, overall. About 85% SOC.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
