Shwthomas1975's avatar
Apr 08, 2014
Going to try to explain this....LOL...Need help
Morning.....First camping trip was last weekend in our hybrid trailer.
No power so used battery and generator.
Last year the battery would last quite a while. This time it lasted til about midnight both nights (woken by the blaring carbon monoxide detector LOL). Was running the heat, but that didnt matter in the past.
Did a little poking (I am no electrical guy). Noticed that when the generator was plugged in the 4 electrical charge gauge lights were only 2 high. Last year they were 4. When I plug it in, it's only 3.
I also noticed that when I turn off the breaker for the fridge, the lights dim and then go out. Took ff the cover and the fridge breaker also has the wire to the inverter. So when I turn off that breaker, the battery isn't charging anymore. But, why would the lights dim?
Any way to check for a bad breaker?
Any help would be greatly appreciated....
  • BFL13 wrote:
    IMO you are not in the clear yet. The converter in a 2001 rig is likely one that should be doing 13.6 or so. Outside chance it is a 9100 and can do 13.2 but not until it has sat for a while at 13.6.
    Find the battery lugs on the DC fuse panel inside the rig and take the converter voltage there. Should be 13.6. Then at the battery should be almost 13.6 with a full battery.
    If still 13.1 suspect corrosion at connections--especially that battery neg ground wire at the frame.
    You might want a better converter to look after your new battery, but IMO first get the wiring etc for this one cleaned up and working right. On that, be sure your new fuse/circuit breaker can handle say 60amps for any new converter you might get in future. That original corroded one may be too low in amps for that.
    X2 BFL is most correct.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
