MEXICOWANDERER
Apr 24, 2019Explorer
- I have a nice white cinder brick wall I use for lighting including 120 volt flood
- I compare their intensity to my car's low beams
- The 18 watt CREE spotlight has an elliptical pattern not round
- And the elliptical pattern does not have a gradual taper. The fringe decay is within 18" at 30'
- Play outside the fringe decay over top the headlights on low beam and there is not a detectable rise in illumination
- Three friends agree. Scatter is inconsequential
- All this would be for naught if the CREE were aimed higher and straighter
- I want an ellipse at 30'
- Remember the stainless steel Per-Lux lights with the defector shutters? With the downward and to the side severe angles the CREE lamp's spot is brighter where aimed but much dimmer outside the hot spot
- The Per-Lux were a ***** to oncoming cars with wet pavement
- The CREE will be aimed at the shoulder
I do appreciate your comments :)
Offer The New Breed of Cop mordida and there will be 2.000 pesos tacked into the fines for the light bar.
I promise the first time the CREE's get flashed down, off they come.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
