"After you moved...then stopped....did you check the batteries for correct voltage/amperage????? When it "tries" to go...are the batteries being drained, or do they hold voltage/amperage???"
Well, not as I was trying to move. But I did check before I plugged the charger back in and I got a reading of 35.**v overall. When I plugged in the charger the needle did go back up to middle range on the gage and it was about an hour before it dropped back down to 0. After letting it set over night unplugged it still "rocks a little" but will not move.
