Almot's avatar
Almot
Explorer III
Nov 30, 2018
Good cam locks, not too expensive?
Bought a set of tubular cam locks for hatches. Infamous Camco brand. Junk. Quality of $8.50 locks is at par with Ebay offbrand cr.apola that you pay 90 cents for. They should be put in front of a firing squad on the next lunch break (if they have lunch breaks in Shanghai). Together with the US middlemen/importers.
2 out of 3 locks can't be installed at all, one is barely functional.
Big nut holding cylinder to the door is so loose that you can pull it off the threads without twisting - in other words, you can pull the cylinder out.
Locking "arm" has a square hole so small that it doesn't fit the square boss on the cylinder, had to file the hole wider.
Past return window, lost $25.
Any source for better cam locks? You know, those with tubular keys. Have found these guys https://shoprvlocks.com/ - formerly ch751.com, double cost compared to Camco. Quality... have no idea. "Assembled in the USA" could simply mean putting the cylinder and locking arm together.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
