Leaks's avatar
Leaks
Good Old Mold!
Hello again.
In the process of sealing up the factory made holes (that were never sealed/foamed), I've discovered some powdery green mold. The mold is specifically behind the shower stall and up one wall that also happens to have a GAPING hole to the outside.
The finishing work on Gateway Campers is absolute trash.
Ok, so I sprayed bleach water behind the shower and into the open spaces of the wall i opened up after wiping away the majority of the mold (I use a mixture of rubbing alcohol and vinegar). The mold is mostly gone from what I can tell. I will seal up the holes to the outside and install a micro-fan to force air through the bottom/back of shower stall and that wall just to make sure there no future issues.
Heres my questions. Am I just getting a string of bad luck because I keep it cold inside and we're in S. FL? Or, is this typical of campers, but it goes unnoticed because most aren't willing to remove walls of their $70,000+ campers? Are there other places I should look specifically that you've seen or heard of before?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
