ChooChooMan74
Nov 13, 2015Explorer
pianotuna wrote:PianoTuna, I think I will do that, also. At least the ones I use high amperage devices on like the heater or coffee maker (Thinking about getting rid of that, too, and just perking coffee on the stove)
Hi,
It behooves you to replace that "standard" outlet with something sturdier than the "stab" type connectors that may exist in most RV's. I've replaced all of mine except for one.
If there is a 30 amp service for continuous loads it may be best to run at 80% of that capacity (24 amps). Assuming 120 volts that allows 2880 watts for all loads.
It is good practise to check all devices in an RV for wattage using a kill-a-watt meter or similar device. The name plate wattage is approximate on every device I have checked.
I have three shore cords now. The OEM 30, a 20 and a 15 amp.ChooChooMan74 wrote:
I brought 2 electric heaters with me. I plugged one into a regular wall outlet
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 20, 2026
