ktmrfs
Nov 14, 2015Explorer III
ChooChooMan74 wrote:kellertx5er wrote:
Many myths and electrical misinformation posted in here. My first ever post addressed the myth that "circuit breakers trip at 80% of rating." Depending on any of many factors (age, temp, mfg., etc etc) a breaker could trip at 10% or never trip at all. The misinformation gets even worse when discussing conductor loading and ratings. Any breaker in reasonably good condition should easily carry 100% of its rating continuously at temps <= 104 F.
Pop quiz: according to the NEC, what is the ampere rating for #10 type THHN conductor (<=3 conductors in raceway, ambient temperature 86 deg F)?
a) 25A
b) 30A
c) 35A
d) 40A
Just looked it up. THHN says 40 Amps #10. Is that the new wiring standard? THHN wire? I am trying to find out what the TW UF wires are, that are rated for 30 Amps at #10.
amp rating depends on how the wire is run. std romex has a lower rating than single insulated conductors in a raceway. part/all of the difference is related to the temp rise in the wire at rated current. romex has 3 conductors in an insulated sheath so it will have a higher temp rise than conductors in free air. and romex can end up being run through insulation as well.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Jul 20, 2026
