  • Wanna laugh?
    Take a look at salt, on a supermarket shelf. It too has an expiration date. "Ohh Heeeeerb?"
    The silver lowers the solder melting point by a couple of unnoticeable degrees. But I like the "WATTGATE" gold plated duplex receptacle! "For audiophiles who insist on providing the very cleanest power to their expensive system ($169.00)"
    There is no way in hell a 2% silver alloy will "improve" music or anything else. So sorry. It's main function parallels the "Wattgate Effect". Silver has poor resistance to atmospheric corrosion. No! Silver oxide is not a great conductor.
    Lead/Tin/Bismuth on the other hand can reduce liquefaction of the media by 20+ F which can be critical where overheating a component would be a real danger.
    The mast anchor light on the Kelley II, was a 40 watt 130V incandescent bulb, that had a 6-amp 1,000 PIV diode in line. I soldered the mast wires to the bulb tip and threads, then dipped the entire brass base in hot tar. Last I heard, the 1983 installation worked just fine. All done with 63/37. Nine and one third 5 pound rolls of it used on the vessel.
    That shelf life hocus pocus is focused on the resin. Burn off a piece rather than snip it and the resin on the roll is sealed............duh! It's @#$%^&! like this that makes me an authentic cynic. I just purchased a quarter pound of ARCTIC SILVER EPOXY. "They say" shelf live is 2-months, refrigerated. They do not say anything at all about shelf life at -0F............duh!
    By the way your salt "expired" on 4,329,652,208 B.C.
    Whose to blame most, crooked companies, or 3-Stooges grade, general public? Golly gee, I came automatically with a Lifetime Warranty. Warranty extension plan not available...
  • Oh my, it only has a 3 year shelf life! I've got some 20+ year old solder I better toss.
  • What does adding 2% silver to the solder alloy do? I'm more used to 40 years ago turning lead with a dash of tin and some antimony, in the form of wheel weights, into cast projectiles for cheap bullets, casting my own. Elmer Keith woulda been proud of me.
  • Something like that would have an online lifespan of 11 seconds max. I tried silver several times and did not see any difference at all, from micro amps to mega 1,000+ amps. If I desired bulletproof it would be in the form of 100% Au
    To novices, this stuff is $42.00 solder at less than 1/3rd the price.
  • Let mu just drop off the camper from my dually and I am coming over with cash.
  • Shoulda been more specific.. SN62 with a tad 2% Ag added. Makes ALL the difference.
  • Sorry, it's the cheap spread Sn63Pb37 Heh heh heh
    It's right in the headliner of the item. I checked shipping and it's very reasonable. I am ordering 4 rolls on the 1st.
    I can tell the difference between 60-40 and 63-37 which usually sells at a premium over the 60-40
    It's waiting for you SCVJeff :)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
