BFL13
Nov 07, 2015Explorer II
Yes, I think it would be 0.9x In another thread somebody suggested that PF changes with output, so if true you would have to specify PF at some particular level.
PowerMax is working on a better spec sheet which I hope will have more info on PFs and inputs for each size converter, making clear if the stated input is the VA with PF or just the watts and you have to apply the PF, which should be there in the spec too.
The other brands' spec sheets are not clear on that either.
EG, you should be able to tell from the specs if the PF corrected 75 draws about the same VA as the non-PF 60, and whether you can run it on a generator with a certain known continuous VA rating.
Fingers crossed PM gets it right with the new one coming out.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
