RDMueller
Nov 07, 2015Explorer
landyacht318 wrote:
I've got a sears clamp on Ammeter whose accuracy is surprising at low numbers.
It accurately measured 0.08amps of an LED bulb that was being run through my friend's Fluke meter leads.
I also had one Wattmeter that was also accurate at low currents. but my other RC wattmeters were not as accurate.
I generally use more than one measuring tool on any suspicious reading or one which needs confirmation.
I also have a shunted battery monitor buts its resolution is only 0.1 amps
Ok, good to know that those are accurate. That's actually a perfect solution in my situation since I'm not installing any of this in the RV. A handheld will be much easier to work with than trying to wire in a shunt.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
