BFL13
Nov 09, 2015Explorer II
Nope :) AH out is what you see, but AH in has the heat loss, so you must put more in that you get out.
How much to allow for heat is a moving target. From 50-70 SOC not much heat, then 70-90 there's more as "gassing voltage" is reached, then there is a lot from 90-100.
Trimetric picks a compromise amount which you can adjust if it doesn't match your own results.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
