MrWizard
Jun 10, 2017Moderator
your NoCo is fine, short length 18 ga will carry 10 amps no problem
NEC ratings are For wires hidden in walls, running thru pipe, hundreds of feet
where heat can not be allowed to build up and cause a fire
in RV battery power use, its all about avoiding voltage drop to the batteries or to the inverter, much smaller wire could be used in most cases regarding the amps involved and be perfectly safe, it just would NOT be as power transfer efficient because of voltage drop
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
