MrWizard
Jun 15, 2017Moderator
Too bad Mr. Wizard's recommended inductive panel ammeter has a poor voltmeter. But glued to the top of the Megawatt case with GOOP, his inductive ammeter plus a reliable voltmeter (I like the DROK 5-digit) will do anything you want to do.
single space decimal point accuracy
13.47v will only display as 13.4v
3 numbers 1 decimal point,
https://www.amazon.com/dp/B01DDQM5PK
i found it on Amazon
i put one on each of my two converters, the mounted PD-70 and the adjustable 75 boondocker, i use as a portable
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
