CapnCampn
Jun 22, 2017Explorer III
MEXICOWANDERER wrote:
THE LOWER THE POTENTIOMETER RESISTANCE THE HIGHER THE VOLTAGE
Sooooooo.........
Why not use the onboard potentiometer? Preset it to whatever float voltage seems acceptable?
But
Instead of an external potentiometer like a 10-turn pot
Use a wind up 6 hour Intermatic Timer
With a resistor in series?
Resistance is cumulative, so a test will be needed to discover what resistance of resistor is needed to achieve a timer controlled absorbsion charge voltage. Big deal. A timer and resistor makes a 2-stage charger.
That's an interesting idea, just parallel the timer/resistor combo with the existing pot. When the timer is on, the parallel resistance is lower than the pot itself -> higher voltage. When the timer turns off, the additional parallel resistance leg is removed from the circuit, raising total resistance & lowering voltage again to the preset float value.
I like it. :)
CC
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
