pianotuna
Jun 27, 2017Nomad III
Using an inverter to do the draw down may tend to increase amps as the voltage on the jar drops. The inverter does its level best to keep the voltage up on the output side.
I would put a kill-a-watt meter between the inverter and the load so you can monitor watts, amps, output voltage and total watts used.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
