RDMueller's avatar
RDMueller
Got the Drok and an ammeter
Now how do I adjust the pots? Voltage should be easy, just connect it to the power supply unloaded and adjust the voltage pot until a voltmeter reads the desired voltage.
But amps...
The ammeter won't read anything without a load attached. So do I attach it to a load with a higher rated draw than what my intended setting is, then adjust until the ammeter reads the desired amps?
  • This is the model:
    DROK® 600W 12A DC Boost Voltage Converter 12-60V to 12-80V Step-up Power Supply Transformer
  • In about the center, there looks to be two dip switches.
    Looks like "in- check" with voltage next to it.
    Yes, it looks like a bucking and boosting type regulator.
    What is the Drok model number?
  • Matt_Colie wrote:
    If you give us a hit what it supposed to do and where you got it, someone might be able to help.
    It look like a DC Buck/boost, and as such, you are setting an output voltage and a current limit. Set the voltage where you want it and turn the I limit down until it shuts off. Then go back a little.
    Matt
    Sorry, this is essentially a continuation of several earlier threads on the subject of manual battery charging. I probably should have just continued on the previous thread, it would have made more sense. Anyway, you are right, it is a DC buck/boost.
    Hmm.. not something I'm intimately familiar with.
    What's the unit's current limit? What happens if you exceed that?
  • If you give us a hit what it supposed to do and where you got it, someone might be able to help.
    Matt
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
