RDMueller's avatar
RDMueller
Got the Drok and an ammeter
Now how do I adjust the pots? Voltage should be easy, just connect it to the power supply unloaded and adjust the voltage pot until a voltmeter reads the desired voltage.
But amps...
The ammeter won't read anything without a load attached. So do I attach it to a load with a higher rated draw than what my intended setting is, then adjust until the ammeter reads the desired amps?
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: May 04, 2025
