dewey02 wrote:
I sent a message to Grape Solar's customer service email asking the following:
Does the controller's remote monitoring only work with Android devices with bluetooth, or does it work with iPad or iPod with bluetooth?
When I requested the app, Grape responded asking if I needed Android or iOS? I needed Android so I assume an app for Apple is also available.
mike-s wrote:
It looks like that controller has low-side control (i.e. all control and measurement occurs in the ground circuit). How did you wire that into an RV, which typically uses the chassis for ground? If it's just wired inline between panels and battery, it should be fine. But the load terminals would be useless, as would any measurement reported for the load.
I don't know if measurement is on the ground side but when I installed the controller the panels went direct to the controller with no connection to chassis ground. The batteries did have a connection to chassis ground. An Engel cooler was connected to the load circuit with no chassis ground. Readings on the display showed both current from the panels and current going to the load.
