Vintage465
Dec 31, 2015Nomad
Greaseable Wheel Bearings?
So on my 2015 Creek Side it has the grease zerk fitting on the dust cap on each wheel. Years ago I worked in a trailer shop and saw many sorry faces that came into the shop with the hub, wheel bearings and sometimes the spindle destroyed that had "bearing buddies" installed and when they "greased their wheel bearings" with this set up all they were really greasing was the nut and cotter pin. So my question is: Do these work differently on the new set ups? Is there some kind of channel carrying grease to the back bearing? Or is this the same old thing that greases the nut and cotter pin. You would have to have the entire hub filled with grease before and greasing from the out side would reach the back bearing.
Thoughts?
Thoughts?
