BFL13
Mar 25, 2014Explorer II
If it is just the slide and the pump but the lights are ok when those two things are dead, it is not your battery fuse/breaker.
Both those have grounds to the frame in about the same place? Loose connection(s) get(s) hot? Older trailer you can lose a ground with corrosion.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
