Creepy2169's avatar
Creepy2169
Gremlins in my camper
This might be lengthy. So it started with my water heater not working. I have a jayco 264 BHW travel trailer. I hit the switch, it illuminates, and then nothing. It is a gas powered Atwood hot water heater. Normally the switch comes on, click click click, pilots up then it’s working. I have absolutely nothing. Figured must be a gas issue. I don’t play with gas so I called out a tech. He replaced the computer, the gas valve, and the thermal fuse thingy. Still no worky. At that point I happen to notice the furnace also does not work. Same thing, click it on, and nothing. Normally at least the blower would kick in and then heat shortly thereafter. I get zero action. So tech guy leads me to the battery. It’s shot (only 6 volts) so I replace that. Still broke. So I start chasing grounds. I have checked, cleaned and reset every ground I can find. Still nada. Then by some Miricle, my son and wife come up and everything works fine, for a day. Now it’s all broke again. I think it’s cursed. I have also check all fuses by removing them and using a multimeter not just visual inspection. We are on a seasonal site so taking it out is a large hassle but might have to get done. My tech is confused and at a loss. The stove works just fine so I have gas output. Now lastly I got the electric bill for the site today. My usage is triple almost anyone in the park. We are only here on weekends and rarely have used the A/C so far so I can’t understand what is burning so much energy. My bill was $90 for 2 months and a guy that basically lives here we only $74. I’m leaning towards my power converter being bad. When I had a bad battery the fan went almost constantly. Now with a new battery it is rarely on. All that stays on is the fridge which can’t possibly eat that much juice.
Anyway. Hopefully this makes sense to someone because My next step is to yank it and lite it on fire. Thanks for any guidance anyone can give.
  • Folks, thank you for the quick responses.
    As to the tech, yeah I have lost faith in him. He was walking me through why he was replacing the parts, but now he’s as lost as I am so I think his knowledge may be limited. Haven’t found a mobile replacement for him so I may have to pull the camper. It’s a bit of a hassle to do that though so I’m trying other options.
    The battery I did not check the water levels, but I did need to move that. Should have said in the beginning it was the original battery, and it sat for about probably 18 months unused. Do to my own negligence, I should have at least had a trickle charger in it, b didn’t. The new one appears to work fine, the fan for the converter isn’t on constantly anyway.
    The other stuff I will try out. Again thanks for the input folks, we shall see what my meter skills find.
  • Unplug from shore power and see if the water heater and furnace work from your new 12v battery.
    I agree the high electric bill could be from trying to charge your old battery.
  • Could the $74 guy be using an extension cord to your pedestal during the week while the park is empty? Really just kidding on that one but I couldn't help it. :)
    Going off the electrical gremlin theory. Unplug the shore power cable and bleed any surface charge off the battery. Try to get the furnace blower running for about 3 minutes. If you can't, then turn on every 12v electrical appliance you can for three minutes. Think range hood vent, bathroom vent, overhead lights etc. After three minutes turn everything off and let the battery rest for a minute or two. Now take some readings.
    Pay attention to battery voltage. What I mean by that is measure your voltage across the positive and negative posts on the battery and write it down.
    Now anytime you measure for DC current whether at the fuse box or at the water heater board, you're looking for battery voltage. If the battery is at 12.67 volts, you should see 12.6x volts or at least close to 12.6x volts at the water heater. If you don't, then start going upstream until you find the voltage drop.
    Measure the voltage at the furnace or the water heater with the appliance turned off. Then turn it on and measure again. Are the two readings close to the same?
    Starting to think further, you might have a high resistance problem. A multimeter pulls almost no current. So it will measure 12 volts through a single hair thin piece of wire that would never support a furnace fan. If you have a big voltage drop check on the trailer tongue for a circuit breaker or fuse on the positive wire from the battery. If a circuit breaker make sure you have the same voltage on both posts on the breaker.
    You can always jumper the two posts with something to rule out the breaker itself. If the breaker is bad they are available at any auto parts store and probably at Walmart as well. Just make sure you look at the amperage rating on the side of the old breaker as like fuses they come in various amperage's.
    You can also check fuses by taking a measurement off back of the fuse. Poke the positive lead of your meter into the slots on the back of the fuse by the rating number. Those slots are at the end of the two blades on the fuse so you can take reading without unplugging. You should get the same reading on both slots. If the readings are different replace the fuse.
    If you suspect a ground problem, or just want to rule out the ground you could make a temporary ground. Use a spool of wire, some jumper cables clipped end to end, a length of copper pipe and some alligator clip test leads. Something to give you a long return path to the battery. But if you use a fabricated ground, make sure you take your battery voltage test at the battery using the extended ground.
    As far as your converter charger the easiest check is to plug in the shore power cable and do another battery voltage check. You should be getting around 13.6 volts at the battery. Again, you should be getting close to that same voltage at the fuse block, the furnace, or the water heater.
    The high power bill was probably your charger running full bore trying to charge up the dead battery. If you suspect anything else then turn off and empty the refrigerator and bring the food home. Flip the main breaker in the trailer not at the post and disconnect all negative wires off the battery. Take a picture of the electrical meter and then head home. The next weekend take a look at the electrical meter when you return and make sure it's the same. Hook up the battery, flip the breaker back on and turn on the refrigerator. Reload the fridge with the pre-cooled items from home.
  • K Charles wrote:
    Get rid of the parts replacer and find a technician.
    Well stated as he knows little else. Many and I mean MANY RV problems are battery related and should have been the first thing checked. Next would have been does everything else work?
    A $10 voltmeter from HF might be a good friend to know.
    Power bill: Buy a Kill A Watt and pedestal adapters to determine your rig AC usage. Turn off all rig CB's first then on one at a time and observe usage. Notes: The KAW is limited to about 15A. Turning off the CB's may cause a reset and the problem not be apparent when turned on again. But given your power bill don't blink an eye at the low cost and very helpful equipment.
    BTW Did you leave the HW on?
    I assume you paid this idiot? What a wonderful way to make money. They have NO idea what they are doing and they get paid to replace parts. You paid labor and Parts Mark up. How much did you pay him? When was the last time you checked the Battery Water before you replaced the Battery? Full 24/7 hook ups, you must check the water weekly. Even a BAD Battery, the Power Converter would still supply 12 volt power. UNLESS, the Power Converter is Bad. What you need to do is, Disconnect and get your Trailer to a regular good RV shop. Otherwise you will continue to pay for worthless help. You have so many symptoms and problems and your tech knowledge is very limited so help from us would be a waste of time. Doug (41 years as a RV tech, NOT a Mobile tech)
  • I had a motorhome that suffered similar problems and it turned out to be a gfi. that may not be your problem but its worth taking a look at
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
